Something could be stuck inside of your washing machines drain or the hose could be needing to replaced or the hose could be kinked or twisted or have holes in it. Or the wires are either broken or loose in the water valve or the washing machines wiring harness and have to be replaced.
How do you reset the filter light on a Whirlpool refrigerator?
To reset the light, simply locate the water filter button and hold it down for 3 seconds. Keep your water filter in good condition by changing it regularly, using Whirlpool filters, and getting your fridge serviced by a Whirlpool technician.
https://www.manualslib.com/products/Whirlpool-Gss26c4xxf-2840449.html
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
I just bought four washer and only one of them are working the other three has all lights on and does not want to work at all can someone help me please as the washer were shipped out of the state, desperately seeking assistance???
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
