SOURCE: Removing the control panel on the 1800XL to replace the fuse
Unplug microwave. Remove the two phillips head screws from the top at the very front edge, allowing you to remove the top grill. This will give you access to the one remaining screw holding the control panel in place. Lift panel up a bit and you're in. Note: even an unplugged microwave can hold a nasty electrical charge if the bleeder resister inside the capacitor is bad. Be cautious and don't touch things unnecessarily.
SOURCE: Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
SOURCE: the pump on my hoover washer hnf7148 has been
This particular model has a problem with the circuit board(control board,PCB) it does everything but drain, its very easy to replace and costs around £52
SOURCE: start/pause button not working - button will not
Hello, Daron I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
it might not be synced plug it in to the charger cord then press the ps button on controller 2 should solve the problem.
Testimonial: "appreciate that. i was using a charger stand and controller wouldn't sync. thanks again."
