The microwave suddenly wont run, a dinner plate light and a diamond with a line in is flashing and non of the buttons are working. Is there a way to reset it?
SOURCE: Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
SOURCE: microwave
Meezy, that plate is called a "wave guide cover" and it's shorted out for a reason, (the part number is WB06X10541 and it appears to be a Factory order part). The reason it's shorted is probably due to a failed magnetron, the component used to create the microwaves. The magnetron carries a 10 year warranty from GE. Call 1-800-GECARES for a warranty repair. You'll need the complete model and serial numbers... they are on a sticker inside the microwave. Hope this helps!
SOURCE: GE microwave heated food for
Possible causes:
SOURCE: I have a microwave unit
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: KENMORE ELITE MICROWAVE
F3H is a humidity sensor error.
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If it still fails, you have a bad sensor.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
