20 Most Recent Daewoo KOR-1B4H Microwave Oven Questions & Answers
Maybe time for a new one. But just in case check the power outlet still has power and the circuit breaker is not tripped.
Daewoo KOR-1B4H... | Answered on Dec 01, 2015
where I want to take my microwaveoven for repair in Kuwait, it still in its guaranty period
Daewoo KOR-1B4H... | Answered on Apr 30, 2014
Connie, look inside to see if something metallic is in the oven, like aluminum foil. Sparks should not be present. Also remove the grate/shelf if there is one and check under the turntable for metallic pieces. Actually take the turntable out. Test using a glass of water. 1/2 min on high, water should get warm
Daewoo KOR-1B4H... | Answered on Apr 23, 2014
Chances are you have a bad door switch or the switch's mount is loose, misaligned, or broken.
See my help file here.
Daewoo KOR-1B4H... | Answered on Dec 28, 2013
I don't know your model but where the light previously was coming through a lens either remove the lens and replace the bulb or remove a square panel just opposite it on the side of the microwave to replace the bulb.
Daewoo KOR-1B4H... | Answered on Nov 28, 2013
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Daewoo KOR-1B4H... | Answered on Oct 02, 2013
Try contacting Samsung for the SE error. They fixed my SMH9187ST microwave for free even though it was 4 years old. 08/14/2013.
Daewoo KOR-1B4H... | Answered on Aug 14, 2013
I have KOR 6305 Daewoo microwwave its fuse burn always what problem?
Daewoo KOR-1B4H... | Answered on Nov 25, 2012
It can be fixed but it will be expensive, from the description the problem is in the keypad control board or smart board.
Daewoo KOR-1B4H... | Answered on Apr 06, 2012
Hello Amal,
Daewoo Electronics
Ghadet El Maadi Tower,
Corniche El Maadi, Maadi, Cairo
Tel: 02-25256533, 02-25256633
Daewoo KOR-1B4H... | Answered on Dec 13, 2011
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://dl.owneriq.net/9/9d7ecbaa-d479-4366-b15a-561c529fde97.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Daewoo KOR-1B4H... | Answered on Nov 10, 2011
Daewoo KOR-1B4H Microwave Oven Logo
86 questions posted
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Microwave Ovens
Most Popular Question
microwave not heating everything
  • Microwave Ovens
