Question about In Microwave Ovens
Press the clock button for 3 seconds: the hours digit will flash. press the +/- to set hour. Press the clock button again: the minutes digits will flash. Use +/- to set. Press the clock button again. Done....
Posted on Oct 29, 2017
SOURCE: Jenn-Air clock set for 24-hour
Check the control setup chart on the same page in the middle column.
Press CONTROL SETUP > 3 > 2.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
SOURCE: Lost instruction manual as to how you reset time on clock
Go here to download to your manual:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!
rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 30, 2008
SOURCE: Whirpool microwave resetting clock
Whirlpool Microwave X2-30ES
I was pressing one too many buttons.
Press Clock, then Stop, press in the 24 hour time digits, then press Clock again.
Posted on Nov 03, 2009
SOURCE: I am unable to set my clock on the Magic Chef
Typically all you have to do to set the clock is to press the Clock button, enter the time, and press Clock again. However on some models, clock set is accessed through the main menu, by pressing the Help button and following the prompts.
Posted on Feb 05, 2011
SOURCE: I need a Lamona microwave/grill manual
Start by contacting you distributor of the appliance to get a lead on the manufacturer. They will provide the manual. Be sure to state whether you want the customer user manual or the technical manual.
Posted on Oct 21, 2013
