SOURCE: GE Refrig runs short time and shuts off
could be a sensor, 6 dollars, could be the mother board, could be the compressor or overload, could be encoder board i would call factory service, some of these parts are high dollar
SOURCE: not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
SOURCE: GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
SOURCE: New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
