20 Most Recent GE GBS22HCR Bottom Freezer Refrigerator Questions & Answers
you need to replace the temp sensor. Here is that part to order.
GE GBS22HCR... | Answered on Feb 22, 2013
you have a bad motherboard the clicking noise is coming from the lights relay. the part# is WR55X10656 it is a plug and play part so you can do it yourself. I got your part number through partsdirect.com its about 130.00 you maybe able to shop around and find a better price. thx for usinf fixya peyton.
If my solution helped pls rate me accordingly..
GE GBS22HCR... | Answered on Sep 21, 2012
My first guess is defrost timer, is stuck in defrost, if you can find it, turn it, and if the compressor and fans turn on, you got your answer.
GE GBS22HCR... | Answered on Jul 01, 2011
There might be a minute electrical problem , inside the circuit , this can be solved by a electrician. or its better to call the service person from the company itself . You can download the service manual here-->http://www.fixya.com/support/p127816-ge_gbs22hcr_bottom_freezer_refrigerator/manual-12280/page-25#
Thanks for rating Good luck
GE GBS22HCR... | Answered on Feb 10, 2011
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
GE GBS22HCR... | Answered on May 24, 2010
This sounds like it is not defrosting, plus the drain may be clogged not letting the water drain. The drain clog will not block the fan, but not defrosting will.
GE GBS22HCR... | Answered on Jan 03, 2010
Hi.
If you: "shut off everything for a couple of days and then turn back on to have everything works for about 5 to 6 weeks and then refrigerator section stop getting cold again."
Then it is likely the defrost system.
The defrost system is located behind the unit back panel, and its function is to keep condenser coils free from frost.
If the defrost system is not working fine, the condenser will go under stress and the unit will produce insufficient cooling, particularly on high temperature conditions.
If it is a defrost system problem leaving unit to defrost completely will fix the problem for few weeks, then it will restart in consequence of the missing defrost function, and of ice on the condenser coil.
The defrost system comprises of an heating coil, a thermostat, a fan.
Heating coil and thermostat are tested using a multimeter to read Ohms on the part contacts, the fan is testing energizing it.
If you want a quote on repair you can contact the phone number listed on the user manual.
Here parts and diagrams for the model in title.
Regards.
GE GBS22HCR... | Answered on Nov 24, 2009
Can you get me the complete model number?
Let me know, Sea Breeze
GE GBS22HCR... | Answered on Mar 22, 2009
Check for a blockage around the through area from the freezer to the refrig. or something such as a jug of milk that you keep in the same loacation time after time. if this jug or what ever stays in this area that can cause a cold spot and keep that area from getting warm enough to let ice thaw.
GE GBS22HCR... | Answered on Mar 10, 2009
This is common, your machine needs a new defrost klixon. or it is (the klixon) loose from it's mount. Turning off the mach. gets a good defrost and
all is good for a time.
GE GBS22HCR Bottom Freezer Refrigerator Logo
38 questions posted
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
inglis fridge model irt184300 warm
  • Refrigerators
