Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE SIde By Side - No cold air on the freezer side.
This side by side refrigerator runs all the time, I hear the external fan, but there is no cold air from the freezer side, the coils in the back is covered with frost.
Model Number GSS2011MD-WWW, purchased in 2002
Posted by johnch99 on
Gerald Griffin
  • 248 Answers
Do you hear fan running in freezer? Should be on when you hear that external fan. If not, you may need an evaporator fan motor. Also check board in back for burned resistor. May need to replace both.
If that fan IS running, remove lower rear wall of freezer and inspect the defrost heater. It's at bottom of coils. It has a wire leading to both sides. Remove with 2 screws and check for continuity. If open replace defrost heater. This is a common failure on these.
Posted on Nov 18, 2007
My freezer is not blowing cold out. I hear the compressor running but its not getting cold
most likely bad evaporator fan motor located behind the wall in the freezer,when you open the freezer door you should hear the fan blowing in the freezer unless it's in defrost,if you don't hear it check it in 45 minutes if still no fan it's bad.
Oct 03, 2014 | Frigidaire FRS3R5EMB Side by Side...
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Top of freezer is fine but the bottom isn't as
Sounds like your evaporator fan is not doing its job. The purpose of this fan is to move cold air from the evaporator coil (behind the lining of the unit) to the rest of the freezer and to the refrigerator.
The fan should be behind an access plate at the top of the freezer compartment. If it is running, you should be able to hear it. If you don't hear it, open the access plate and look at it. If the fan is not turning, you will need to replace the fan motor.
Oct 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Freezer stays cold and refrigerator side is warm
First check that nothing is blocking air circulation to the fridge from the freezer. Is the fan running ? You can usually hear it when you open the freezer. If not running , it needs replacing.
Jul 03, 2009 | GE PSC23NHN Side by Side Refrigerator
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
104 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
