I downloaded windows 10. Message says fax is not installed. Also there is a message cank print Lexmark can't print Lexmark_Host driver is not on my machine
SOURCE: Lexmark 4350 and Vista
Hi I found that you can download the drivers for vista here http://downloads.lexmark.com/cgi-perl/do... Good luck Redsocks
SOURCE: LEXMARK X8350 COPY,PRINT,SCAN AND FAX
I do so apologize for the problem during our chat session. One second I was typing in the next step and then suddenly the chat program wouldn't send my chat, and the top of the window said server error.
I would have contacted you before but I did not remember your user name until the website management gave me the info.
If you still do not have your printer working, please download the vista driver here (note where you download the file to.)
Then make sure your printer is not connected to the computer.
Double click the driver file you downloaded to start installing the driver.
When the install asks you how the printer is connected, reconnect the USB cable to the printer and pc.
If you have any other problems with the install, just let me know.
And again I apologize for any inconvenience the interrupted chat session may have caused.
SOURCE: lexmark 9500 fax trouble
Pls try:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Panafax UF-7100 showing install developer
Unplug power / plug back in.... NoGo? try this:
Function
7
press monitor key slowly 4 times
6 (RAM INITIALIZE)
scroll down to CLEAR FLASH MEMORY
set (wait for reboot)
If that doesn't work, scroll down to ALL JOB CLEAR and set.
Last resort....
scroll down to SHIPMENT SET
set
2 for no
Did the developer problem go away?
SOURCE: Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
