SOURCE: Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
SOURCE: playing a european PAL game on a canadian NTSC console
Go to a search engine like www.metacrawler.com and search for "Swap Magic". The Emotion Engine processor that is reading the data from the game is told not to read certain Discs if the region code does not match the conoles country code. It mayl save a game to the memory card but not play the game or run the movie.
SOURCE: NTSC console format using games PAL Format
Hi Pirata1963
Nintendo DS Games are actually region free so they should work.
Nic
SOURCE: Play PAL Disc on NTSC U/C PS2 Playstation
Hi speed Play satation gmae plesae send deatils for my ID [email protected]
SOURCE: change from PAL to NTSC
You need to configure it out.
1. Connect the magic sing in your TV
2. Turn on your TV
3. Magic sing should be Off
4. On your magic sing; Press and Hold "8" then while holding "8" press "power button", count for thre seconds then release both buttons (PAL to NTSC)
or
On your magic sing; Press and Hold "9" then while holding "9" press
"power button", count for thre seconds then release both buttons (NTSC to PAL)
