SOURCE: my back speakers wont produce any sound
OK I believe there is a small indented "Reset Button" around somewhere on the back of the unit, With the unit powered ON, & using a small diameter implement, straightened paper clip etc, press IN the button and this should "Reset" ya unit. This may indeed fix all your problems as the Unit "Reads" the speakers at turn on.
SOURCE: 50 plasma tv
It is repairable (or should be). It's not something you can do on your own, though. Parts will need to be ordered and replaced. Any repair shop should be able to get you up and running again. Call around for estimates.
SOURCE: miti 1080 sereies tv won't turn back on
Befor thinking the worst, it may just be a tactile switch, probly the vol. down button switch on the front panel of the set. When you unplug the set and replug it again, does the green LED stop blinking after 20 sec. or so?
If the Green LED does not stop blinking you are talking a major repais on the Main Chasi Assy.
Hope this helps,
Skyassoc
SOURCE: 06 ultra radio no sound from speakers only headset.
Switch is fine. You have a damaged audio circuit caused by vibration. Check the bikes mounting brackets. probably broken. The radio will need to be repaired. www.ironcrossaudio.com
SOURCE: 42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Hi Kathy Cooper, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Make and model number?
