It had just worked i dont know what happended.
SOURCE: last night our power went off and on approx. 10
You might want to take the back cover off and look for blown fuses in the power supply.
Just follow the power cord and you should find one or two fuses in the main circuit board. They`ll have a broken or burnt filament inside the glass enclosure and their values will be written on the end caps.
Replace them, but if they blow again then it means you`ll need repair before the set will work again.
Hope this will help Good luck
P.S please do not rate this answer(unless it helps) since this answer is only a suggestion/information.
