Video Game Consoles & Games Logo
Ann Butler Posted on Dec 13, 2016
Level 181 ? What to do to get the ingredients(2) on each side down?
How do I restore my candy crush saga back to level 181
Is it correctly restored on facebook? If so you should be able to resync it. Go to the app on your phone and ust click on the arrow on the bottom left. Opening up settings and log out of facebook. Then connect to facebook again. YOu should then be resynced to the facebook version.
7helpful
2answers
My new kyocera taskalfa 181 copier diplay call service c3100
please unlock the 2 scanner lock on top left side of the machine. the lock will be in yellow colour and it will covered by red tape.
3helpful
2answers
Renault megane, 2004 1.4 dynamique, brake lights not working (both sides but high level one ok) have checked bulbs, fuses, connections at cluster, loom in areas for visible damage, all other lights ok
Seems to me that the brake lights switch has a problem there is a way to test this problem, you normally press the clutch pedal and hold down the start button to start the engine, now try pressing the break pedal down and hold the start button, if the car does not start up change the brake pedals switch.
I have a Sunbeam Heritage Series Mixmaster, 350 Watts, just purchased yesterday. I used it to mix cake batter, cream butter, whip egg whites....the problem is that it doesn't blend the ingredients. The...
There should be a small lever on the base in front of and below the bowl. It will move to 2 positions. It sounds like you have it set for the small bowl but are using the large bowl. Press down on the lever and move it to the other side. If I'm right, that should correct the problem.
2answers
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
3helpful
What order do i put the ingredients
Start by putting the ingredients in, in the order they are listed. Wet goes in first, then dry. Try using bread flour. It's lighter and more tender. All dry ingredients must be level, not heaping. If you put heaping, you'll have a mess on your hands as the recipe may not mix well. Hope this helps!
[email protected]
Valve pressure renault laguna
you must make sure the senser is the correct one.each wheel senser has to be correct.they are not the same.i think they are colour coded.say rear wheel wont work on front etc.sometimes inflate pressure to around 45psi on side that is faulty then let pressure down to correct level resetts the senser.otherwise think its renault dealer to reset computer
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
