SOURCE: Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
SOURCE: Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
SOURCE: order main drive gear for geha paper shredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
SOURCE: Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
SOURCE: NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
