Question about Achiever CCS5000 Shredder
Where can I purchase replacement plastic gears for my paper shredder. It is a CCS 5000 ACHIEVER. Thank you.
Where can I purchase replacement plastic gears for my ACHIEVER CCS 5000 paper shredder?
    Top Expert:
  • Achiever Master
  • 66,521 Answers
Possibly thru the manufacturer but many do not offer replacement gears .
Posted on Oct 19, 2016
Broken wheel on ccs 5000 achiever
Have you found a source for parts yet. I am looking for one too.
Apr 07, 2009 | Achiever CCS5000 Shredder
Where to purchase a drive gear for Achiever SCS-6 Shredder
Try Miacom.com. All they appear to offer are gears. What about other parts for this shredder?
Jan 12, 2009 | Achiever SCS-6 Strip-Cut Shredder
Achiever, Model CCS 5000, shredder, need a part (a large nylon gear)
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Aug 18, 2008 | Office Equipment & Supplies
Broken Wheel
You should be able to contact manufacturer unless your model has been phased out
Jan 05, 2008 | Achiever CCS5000 Shredder
Achiever CCS 5000 Basket
Did you contact Royal Corporation. Look up the model on EBAY and you can find a replacement. I have a used basket from a customer that did not want to repair their shredder. You can have it if toy want to come to Clearwater Florida
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 11, 2007 | Achiever CCS5000 Shredder
Parts
I am not sure but i suggest check for the manufacturer via the internet
May 23, 2007 | Achiever CCS5000 Shredder
CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Apr 12, 2007 | Achiever CCS5000 Shredder
Noisey Shredder
Have you oiled the blades? When was the last time it was serviced? There is an awful lot of paper shredds inside the unit. Motor bearings need lubrication. Gears need grease, etc. Put about a dozen drops of light oil directly down into the cutter left to right every half inch. I have used vegetable oil in a pinch.
Feb 01, 2007 | Achiever CCS5000 Shredder
Achiever ccs 5000 no power at all
hi check these before enything: 1) check with another device that the socket has power 2) check cable is good all the way (NOT torn, twiched, squashed) 3) the device is hooked up good (in place,NO trash) 4) there is a micro switch on the door which wont let the device work without no good connection 5) check good fuse should work good luck
Apr 05, 2006 | Achiever CCS5000 Shredder
Achiever CCS5000 Shredder Logo
248 people viewed this question
Top Achiever Office Equipment & Supplies Experts
Marvin
Marvin
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
