Charla, By what you have stated, it sounds like a lid switch failure. I recommend checking the screws for the lid hinge first.The lid has to be closed for the motor to run in the washer. If the lid switch is faulty, it will act as if the lid is open. A quick check you can do is to run a cycle with the lid switch jumped. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console.Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and white wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Then start the washer in a cycle, and let it go. If the washer completes the cycle, you need to replace the lid switch. Remove the jumper and order the part. The jumper is only of the test do not continue to operate after test.
Whirlpool Appliance Parts
Whirlpool Appliance Parts Whirlpool Appliance Parts from Easy Appliance...
http://www.repairclinic.com/Shop-For-Parts/a11b5/Whirlpool-Washing-Machine-Parts
