Question about Whirlpool Washing Machines
Use a shop vac to get the water out after the clothing is removed. These links should help:
How to Replace the Lid Switch Lock Assembly on Top Load Washer Repair... Washer Lid Switch Part Number 3949238 GUARANTEED FIT from Sears PartsDirect Kenmore 80 Series Washer Lid Switch Repair won drain or spin
Whirlpool washer stopped working full of water and clothes after opening...
Posted on May 31, 2016
SOURCE: replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
SOURCE: Roper Washer filled with water and then stopped
HI thanks for your question. the problem you are having is with the lid switch, which is located uder the top. replace the lid switch. if you need further assistance . plese get back to me thanks the appliance doc. please rate my answer thanks
Posted on Oct 11, 2008
SOURCE: KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Posted on Jan 31, 2009
SOURCE: Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
Posted on May 14, 2009
SOURCE: Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Posted on Jul 16, 2009
