Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
SOURCE: MY REMOTE CONTROL FOR THE LG TV :32LG30 STOPPED
Let verify first if the remote is sending out signal, point the remote at your digital camera, you shoud see flashing light on your camera screen (camera can see infrared light) when any remote button is pushed, if you can see it, then the problem can be in the Infrared receiver in your TV and need further troubleshooting.
You can get new remote on EBAY.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: I can't turn off the
Hello
In the Closed Caption system, there can be more than one caption service provided. Each is identified by its own number. The "CC1" and "CC2" services display subtitles of TV programs superimposed over the program's picture.
In the Closed Caption system, the "Text1" or "Text2" services display text that is unrelated to the program being viewed (e.g., weather or news). These services are also superimposed over the program currently being viewed.
