20 Most Recent Mitsubishi WT-42315 42" TV Questions & Answers
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
Mitsubishi... | Answered on Jul 22, 2014
May be problem on setting .Please program again or setting multisystems.your tv picture ntsc you should change pal
Mitsubishi... | Answered on May 18, 2014
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Check this site too.
Mitsubishi... | Answered on Aug 06, 2012
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope that this will help to solve the problem....
Mitsubishi... | Answered on Aug 25, 2011
Pictures still have colors shadows mixed into the tv picture wright?Yes?Tv still have and causes by convergence board as a problems.
Mitsubishi... | Answered on Aug 13, 2011
Tv have a problems known as a convergence picture problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board have dead parts like 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must have be replaced to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Mitsubishi... | Answered on Jul 07, 2011
The short answer is yes! when electronics take on water the results in most cases are not good, the ic pins start to corrode working it's way into the casing making it useless over time. If you want to attempt a repair, remove the batteries and any screw, next wedge a fine blade screwdriver to unclip the case, take out the rubber pad and wash with rubbing alcohol, then get an old toothbrush dip in alcohol brush over circuit board a few times and allow it to dry before putting it back together.
Mitsubishi... | Answered on Jun 25, 2011
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mitsubishi... | Answered on Jan 22, 2011
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Mitsubishi... | Answered on Sep 23, 2010
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
IF this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Mitsubishi... | Answered on Sep 20, 2010
Ur tv have convergence problems,it dead.Any colors misaligns,3D pics,shadows pics.The tv convergence board must have it the 2 STK convergence ICS and some or all it resistors are dead,must be change to solved convergence problems.The shop will cost U $300-$350 for parts and labors.
Mitsubishi... | Answered on Jun 11, 2010
set the convergance on it
Mitsubishi... | Answered on Feb 14, 2010
First a few questions?
Does the power light on the front of the set come on for a moment and go off?
The set has one regular fuse at the power cord and several soldered in pico fuses that protect it.
If power light comes on for a few seconds and goes off--do the self check this set has:
When power light goes off press and hold both the Menu and Input buttons on the front of the set at the same time for at least 5 seconds and release---power light will blink a two digit error code--
The most common is 2 blinks, a pause and 2 blinks; set will repeat this at least 5 times and to get it to repeat it you have to unplug set and try to turn on again.
Let me know what you find.
SD TECH
Mitsubishi... | Answered on Feb 04, 2010
YOU WILL NEED PROFESSIONAL HELP THIS IS NOT A DO-IT-YOURSELF JOB. SORRY
Mitsubishi... | Answered on Dec 28, 2009
Chassis VK-20 made in 2002
http://www.techlore.com/downloads/file/7714/WT-42311,_WT-A42.pdf
The service manual can be downloaded here, you will need the free adoe acrobat reader from adobe.com(You Probably already have it)
error 22 says SHORT PROTECT CIRCUIT in the service manual, it has all the wiring and board diagrams as well as replaceable parts and part numbers
Please give me a good rating if this helps you solve your problem, or if this was what you were looking for which I believ it is.
PLEASE KNOW THAT SOME CAPACITORS INSIDE THE TV WILL CONTAIN FATAL VOLTAGE EVEN AFTER UNPLUGGED.
Extreme caution should be taken, death has occured often from inexperience, so please be warned, and understand that neither I or Fixya.com will be held liable for how the info is used, I will only put this into solutions that involve products that can be deadly if serviced wrong.
Thank you very much for the question, I hope this is what you wanted.
Mitsubishi... | Answered on Nov 18, 2009
Mitsubishi WT-42315 42" TV Logo
Popular Tags
48 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
remote got wet now
  • Televison & Video
