20 Most Recent Mitsubishi WD-Y65 65" HDTV Questions & Answers
The power supply may be failing.
Mitsubishi... | Answered on May 14, 2017
Contact any service technician.
Mitsubishi... | Answered on Oct 09, 2013
After replacement of bulb, lamp reset should be done. Have you did it? If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
Mitsubishi... | Answered on Dec 06, 2012
ogrady1428,
I would check the filter on the fan intake first. Remove it and carefully clean it with compressed air.If this does not resolve your problem then I would remove the lamp and inspect the switch in the vicinity of the door for problems. Be very careful reassembling the unit once the door is removed. The interlock swich must be positioned correctly or you will get an error message. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem and how to fix it.
Thanks for using FixYa and for the generous rating. We answer these questions for free.
hardrocko
Mitsubishi... | Answered on Oct 06, 2012
Time to buy a new one.
Mitsubishi... | Answered on Jun 27, 2012
Lamp is usually customer replaceable and instructions are in owner manual.
I would to begin with (set unplugged) get at the lamp to inspect it--if shattered inside look for a replacement.
Google the model number with "lamp" to see what is available.
You Tube has video instructions for replacing lamps on most brands and models as well---not have to read just look.
Mitsubishi... | Answered on May 22, 2012
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
Mitsubishi... | Answered on Jan 31, 2012
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
Mitsubishi... | Answered on Jan 11, 2012
what are you trying to connect to this tv?
Mitsubishi... | Answered on Aug 22, 2011
Mitsubishi WD-Y65 65" HDTV Logo
57 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
tv turned off itself one day pressed
  • Televison & Video
