20 Most Recent Mitsubishi HS-U430 VHS VCR Questions & Answers
I am unsure what you mean.
VCRs are not locked to regions like DVD players are, so unless you have locked it to a table or locked it in a closet, I am unsure how to help you here.
We need more information.
Mitsubishi... | Answered on Feb 24, 2011
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
. Thanks for using FixYa.
Mitsubishi... | Answered on Oct 04, 2010
plz tell us more
tell exactly what you are doing and where does it goes wrong
Mitsubishi... | Answered on Apr 07, 2010
Looks that way,the signal is not getting through the vcr,time for an upgrade
Mitsubishi... | Answered on Sep 17, 2009
Hi Hit the menu button, and look for the word "idioma" which means language, and select that. You should then be able to toggle back and forth between English and Spanish. You may have to look under "opciones config. vcr" which is VCR Setup to find it. Hope this helps, Good Luck!
Mitsubishi... | Answered on Oct 07, 2008
No error code 61 listed, only a 66 error code which indicates lamp issues:
66
A) Lamp did not turn on at P-ON sequence... Check CJ4 circuitry
B) No Lamp Inserted............... No Lamp inserted
C) Disconnected cable between ballast and lamp.... HV connection or lead wire to lamp.
D) Lamp-Enable goes to PWB-MAIN but not to Ballast....Lamp Cartridge Failure
for lamp see the following web site: http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73638
recommend using the manufacture part# as many replacements for Mitsubishi will not work.
Mitsubishi... | Answered on May 09, 2019
Shorted circuit board.
Mitsubishi... | Answered on Apr 10, 2019
Could be you need to set the output volume on your receiver for the soundbar. Most receivers allow volume output for each speaker
Mitsubishi... | Answered on Apr 02, 2019
Go to this link, find the manual and follow the instructions. https://www.manualslib.com/
Mitsubishi... | Answered on Mar 29, 2019
Televison & Video Logo
9 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
am looking
  • Televison & Video
