SOURCE: Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It
can be accessed by taking off the back plate (behind the controls) by
unscrewing three screws and two screw bolts -simple.
I removed
the lid switch and tested it with an ohm meter - instructions are on
this site. You should have continuity across machine-motor, as well as
across machine -line. (These are labeled on the switch).
If you
don't have a meter and you still want to see if that's the problem,
after you have removed the lid switch, short the machine and line
connectors, (you'll see these labeled on the lid switch so you'll be
able to figure out which wires go with what) as well as shorting the
machine and motor connectors. Both of these need to be shorted. That
bypasses the switch and will activate the motor and controls.
That's
what I did to confirm that it was all a "lid switch " problem. I
ordered a lid switch from this site for $24.95 for the repair, and will
use the "shorting process" to do a couple of loads of wash as I wait
three days to get the switch. Good luck.
SOURCE: Maytag Bravos top load gives LF code not working. Any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
SOURCE: Ld error on Maytag Bravo. How to remove items stuck under tub?
if you can see the socks you may be able to remove by making a wire hook with an old coat hanger or something similar if you are able to undo the hose coming out of your bowl to the water pump you may be able to also fish out the coins if you are lucky but the best way is to dismantle bowl let me know how you went
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
SOURCE: I have a Maytag Bravo
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
