GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
Matthew Posted on Oct 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ice maker is shooting water out a drain hose on the back of my refrigerator.
Jorgie the appliance guy
Level 3:
Top Expert:
  • GE Master 5,639 Answers
  • Posted on Dec 24, 2016
GE Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523933
Points
32630
Sounds like a clogged drain line?
Freezer /fridge water/ice in fridge and or freezer, or leaks on floor
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 22, 2007
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Anonymous
  • 770 Answers
  • Posted on Jan 26, 2008
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
yalmer
Hjalmer Lamminen
  • 552 Answers
  • Posted on Feb 13, 2008
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Anonymous
  • 770 Answers
  • Posted on Jun 19, 2009
SOURCE: how do i turn off the ice maker on a ge profile.
You can lift the lever in the ice hopper to turn off the unit, or simply unplug the electrical connection to the ice maker inside the fridge. If your leak is in the line between the house supply line and the valve on the icemaker, turning it off will not solve your troubles. If that is the case, you can turn off the supply line valve.
Anonymous
  • Posted on Apr 04, 2010
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
My does my g&e profile leaks water?
I am assuming that this is a refrigerator. If it is leaking and you do not have an ice maker installed, then the problem is probably the drain hose from the freezer is blocked. All refrigerator freezers go through a defrost cycle to keep frost from forming in the freezer section. Every time you open the freezer door to access the freezer, moisture from the air is allowed in. The freezer from time to time shuts down and allows the ice crystels which were formed by the moisture to melt. This water then is drained through a drain hose down the back of the refrigerator to a pan under the coil at the bottom of the refrigerator. The heat from the coil evaporates the water into the kitchen air before it overflows. Check the hose and drain to be sure there are no kinks in the line and that it is not blocked. That should solve your problem.
2helpful
2answers
Whirlpool refrigerator is leaking cold water from the lower left hand corner.
Behind the refigerator are valves and water hoses going to the water dispensor and the ice maker. Anyone of these hose could have a leak either at the connection or the hose. I would not attempt at repairing this unless you are real familar with this problem or appliance repair man.
2helpful
Trouble shooting kirkland refrigerator
If it does not have an ice maker the drain hose that goes from almost the top to the bottom tray is clogged up clear the hose If you can remove the top of the drain hose you should be able to blow the clog out. Then replace hose on the top drip tray.
I have a magtag MSD2454FR refrigerator that collects a pool of water around the left front foot. There was a sheet of ice at the bottom of the freezer section about 3/16" thick. The ice has been...
On the bottom you will find a hose maybe coming down the back of the refrigerator or into the bottom that looks like it drains into a pan, try blowing on this hose and getting it opened. This will be drain for the evaporator, water and ice you see is because it has no where to go. Hope this helps.
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
1helpful
We have a side by side refrigerator with ice maker that leaks water on to the floor.The water also runs into the freezer part and freezes under the bottom bin. It will not make ice but the ice maker...
Could be one of several things.
The cold water reservoir in the refrigerator could have a leak. Usually located on the back wall behind the drawers.
The ice maker may not be operating properly either, or the hose leading to it may be leaking.
Or the ice maker mold may be cracked.
Or the ice maker fill tube has gotten misaligned with the ice maker.
Let me know what you find, and I can give you more direction.
All assumes the ice maker is acting as you describe. There are situations where the drain tube under the freezer coil will clog, preventing water from properly draining from the defrost cycle.
Water from the icemaker shoots down the back of the freezer
are you sure the water comming from the icemaker or the defrost drain line clogged
Leaking water
Dear Elizabeth,
please rate this following solution if it mends ur needs,else choose fixya.
please perform the following checks,
Water on floor outside of freezer
Water inside the freezer
  • Check for a clogged drain tube
  • If you have an ice-maker, check freezer and ice-maker for level
please rate this following solution if it mends ur needs,else choose fixya.Thank you.
Dripping water from a ge fridge with a ice and water dispenser. why is the water spout dripping?
hello ghreay..
do u've Water on floor outside of refrigerator? plz do the follwing..
do u've Water inside the refrigerator? plz do the follwing..
  • Clean the drain tube
  • If you have an ice-maker, check refrigerator and ice-maker for level.
thank you for using fixya..
2helpful
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Top Refrigerators Experts
vince
Johnny 1000
