When I on the printer it says 'Cassette 1 failure'. Do I need to enter a password for it ?
SOURCE: Printer - Setup
USB-interface; CU- custom format of paper; Plain- paper type.
Default settings in the menu of the printer is: A4 or letter,plain
That is the same thing in the printer driver. Also check format of paper settings in small window of your paper cassette.Turn roller to adjust proper size of paper.
Best regards
SOURCE: Kyocera FS 4000 cassette error
under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
SOURCE: need 2 cassette lift springs
Hello, the parts you are looking for is called the Spring Bottom Part Number 302F809010. They may be hard to come by, A Kyocera Printer Dealer may be able to purchase them from the Kyocera Parts Dept. Use this link to find a dealer within the USA http://usa.kyoceramita.com/americas/jsp/Kyocera/wheretobuy.jsp I hope this helps and good luck with your parts search.
SOURCE: Kyocera Printer FS2000-D says "install
You need to turn off the printer and unplug it then install the items from the maintenance kit.
