20 Most Recent
Kyocera Mita FS 3800 Laser Printer Questions & Answers
How to set up network
Press Menu, scroll to Interface and press the right arrow key. Scroll using the down arrow and you should see the TCP/IP setting. Press the right arrow and turn off DHCP. Then you can move around to change the IP.
Dark spots on my paper
is there a corona wire sliding cleaner on the drum assy? if so it should be firmly at the correct end of its travel - on some printers if it is inboard it will print aline down the side
1102
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here:
Kyocera Error codes
Creases on envelopes
Did you try the different types of envelopes in the : Properties / Device settings ? sounds like there is too much pressure for that envelope try changing the type of envelope and see if it makes a difference.
Problem is replace toner cleen
the best to do is to sent it to your nearest shop, if this is under warranty better to ask the technical inorder for you the prevent further damage on your printer.
Hope it helps thanks.
Sir!
the problem of our kyocera
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Error code 7000:0132959
Error 7000 indicates a toner motor error. If you are using a generic toner it could be that the motor is not strong enough to turn the gears on the toner cartridge. Try changing the toner first.
Product key
Hello there,
Unfortunately, Fixya does not provide crack keys as it is illegal. Using pirated softwares also takes away from you the privilege of having a regular update for security holes and bug fixes for the operating system. Please take not also that by using illegal softwares, it also punishable by law.
To obtain one, you need to purchase a valid license key.
