Dear sir my freezer is working but frige is not working well pl tell me what can i do thank
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
SOURCE: Frige not cooling
Poor
cooling is often the result of a heavy frost build-up on the evaporator
coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor
coils. You can't see these coils without removing a panel on the inside
of your freezer. A sure sign that there is a build-up is the presence
of any frost or ice build-up on the inside walls, floor, or ceiling of
the freezer. Such a frost build-up usually indicates a problem in the
self-defrosting system or damaged door gaskets.
The refrigerator
is supposed to self-defrost approximately four times in every 24 hour
period. If one of the components in the self-defrosting system fails,
the refrigerator continues to try to cool. Eventually, though, so much
frost builds up on the evaporator coils that the circulating fan can't
draw air over the coils. There may still be a small amount of cooling
because the coils are icy, but with no air flow over the coils, cooling
in the refrigerator compartment is quite limited.
Here's an
inexpensive, though inconvenient, way to determine if the problem is
with the self-defrosting system. Remove all of the perishable food from
the refrigerator and freezer, turn the thermostat in the refrigerator
to Off, and leave the doors open for 24 to 48 hours. (Be sure to have
several towels ready in case the melting frost and ice causes the drip
pan to overflow). This allows the refrigerator to defrost "manually."
When the frost and ice build-up has completely melted away, turn the
thermostat back to a normal setting. If the refrigerator then cools
properly, it indicates a problem with one of three components in the
self-defrosting system:
If
it still does not cool properly, there may be a problem with the
refrigerant level or the compressor. You may need to consult with a
qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting
refrigerators all have a set of coils and a cooling fan, usually under
the refrigerator, that need to be cleaned regularly. If these coils get
coated with dust, dirt or lint, the refrigerator may not cool properly.
The coils may appear to be a thin, black, wide radiator-like device
behind the lower kick-panel. To clean them, disconnect the refrigerator
from the power source, use a refrigerator condenser brush (see the
Appliance Accessories section) and your vacuum cleaner to clean the
coils of any lint, pet hair, etc. You may not be able to get to all of
the condenser from the front, it may be necessary to clean the
remainder of the condenser from the rear of the refrigerator.
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
SOURCE: fridg is not cooling.frezer working real good.
Open the freezer compartment and listen for the fan motor if you don't hear it but you can hear the compressor running. youll need to first make sure that the door switch is working( If the lights go off when you press the button it should be okay). You'll need to remove the back panel and inspect the coils if frosted over evenly and the fan still is not working give the fan a little push. if it will not go, you need to see if it has voltage if so, replace the fan. If no check the defrost terminator which only on amanas will keep the fan off. In this case replace the defrost terminator(it look about like 5 quarters, with 2 wires clipped through the evaprator coils in back of freezer.
SOURCE: GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
