SOURCE: how do you put the adding machine tape into the
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
SOURCE: When adding on My Sharp
The P stands for power & usually means you need to change your battery
SOURCE: Why won't my sharp
Your calculator is set for GRAD instead of DEG, it means that it takes your input in gradian instead of degrees. You should press the DRG button until it displays DEG instead of GRAD.
SOURCE: How do you reset the
Look for a CE key to ( Clear Entry) or AC key to Clear All.If you have Memories, store 0 values in them. That is the most you can do to Reset without Resetting. Pardon the oxymoron.
