20 Most Recent Sharp EL-1701C Calculator Questions & Answers
Hi cherycooney,
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off.
Thanks for using Fixya.
Sharp EL-1701C... | Answered on Feb 14, 2018
Just ignore the decimal.
Sharp EL-1701C... | Answered on Jan 11, 2018
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Sharp EL-1701C... | Answered on Mar 31, 2017
My calculator starts but it won't show anything in the window when I presses numbers
Have same problem with the randomly appearing"P" and no end frustration with it. Tried loosening, (...the screws very extreemly tight), tried with no success, then tightened again, but still no success. Thanks, though, for the suggestion!
I have found (somewewhere on the web, sorry cant remember where) that it is only a power error ! So if you see the P.e the calculator doesnt received enough power... All you gotta do is to change the batteries!! Or plug it with the appropriated power cord :)
Enjoy!
F is for floating decimal. If you do a calculation, it will present the results without rounding. For example, 1/2 would be displayed as 0.5, whereas 1/8 would be displayed as 0.125.
The 5/4 rounds the results. For example, if the number of decimals is set to 0, 1/2 is 1. Similarly, if the number of decimals is set to 2, 1/8 is 1.3.
Good luck,
Paul
http://support.casio.com/en/support/answer.php?rgn=5&cid=004001001004&qid=32&num=1
Sharp EL-1701C... | Answered on Jun 03, 2016
Not the exact model but might be useful:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000003742.pdf
Sharp EL-1701C... | Answered on Feb 19, 2015
If you want all entries and answers to have two numbers after the decimal, you should have a lever or slide that shows F,6,3,2,1,0. Some also show Add. Set the lever on the 2 or add. F means floating decimal. the others indicate how many numbers after the decimal.
Sharp EL-1701C... | Answered on Nov 01, 2014
Sharp EL-1701C Calculator Logo
113 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
old sharp el 1701c calculator some
  • Office Equipment & Supplies
