20 Most Recent Sharp EL2196BL Printing Calculator - 12 Characters - Fluorescent - Power A Questions & Answers
Go online and type the above as you asked, then download the corresponding link
Sharp Office... | Answered 2 days ago
  1. Remove the toner cartridge.
  2. Unscrew one screw and remove developer unit. Check if developer is evenly spread on mg roller. If its ok then go to 3.
  3. Remove drum unit and check the upper slit glass and wipe. Return everything back and check copy quality now. If its Ok end there, if not proceed to 4.
  4. Remove the laser unit and clean the glasses if you are a qualified technician. Don't if you aren't.
Hae,
Check the fusing area to see whats causing continuous paper misfeeds. Rectify that particular problem, then key in the following using this sequence;
  1. press #, Interrupt, C, Interrupt, keys using a quick sequence. the display must go off, if not repeat 1.
  2. enter 14 and press copy key.
  3. Your problem is solve.
Just replace toner cartridge or refill the toner container with refillable sharp ar202 refill bottle or sachet. Remember to remove waste toner if you are refilling, right.
Use a Q tip to clean all the rollers with alcohol and check if there is some paper wrapped around a roller.
Sharp Office... | Answered 3 days ago
Sharp H2-0 error code is for the Fusing unit not getting to the correct temperature in a specified time.
You have to reset fuser errors.
Press the "#"key "INTERRUPT"key "C" key "INTERRUPT"key on the panel then press "14" then press Start button (the button you use to make copies) and it should reset the code.
https://www.coronatechnical.com/2019/04/how-to-fix-h2-error-code-sharp.html
Sharp Office... | Answered on Apr 19, 2019
  • Charger cleaner trouble (K). Causes. The main charger unit (K) is not installed properly. There is an abnormality in the main charger
Sharp Office... | Answered on Apr 17, 2019
Requires a service tech to come out, because having access to admin mean changing accounts ETC. don't know if that is what your trying to do so have tech come out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp Office... | Answered on Apr 15, 2019
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
We can resolve sharp printer Dx-C200P fault SC 445 by visiting this link:
https://www.driverscape.com/download/sharp-dx-c200
Sharp Office... | Answered on Apr 13, 2019
What if copier show L1
Google search reports thermistor error. One of several possible fixes described: https://www.thecopiernetwork.com/sharp-black-and-white/sharp-ar-5316-code-h2-20301/
Sharp Office... | Answered on Apr 12, 2019
https://www.manualslib.com/manual/885094/Sharp-Ar-6020.html?page=111#manual
Are any of the indicators shown in the manual displayed?
Can you provide any more information using the Comment menu in FIXYA?
Sharp Office... | Answered on Apr 11, 2019
Sharp EL2196BL Printing Calculator - 12 Characters - Fluorescent - Power A Logo
1 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp 5320 copier make noise solution
  • Office Equipment & Supplies
