Question about Sharp EL-2630P Calculator
Sharp EL-1801V 12 Digit 2 Color Printer
Please can you tell me how to fix my calculator?
When I type in the numbers it shows correct on the screen but it prints out in +%%%000 etc.
What am I doing wrong?
Posted by laurav2000 on
  • 1 more comment
  • thesunchaser Jul 04, 2008
    trying to set time and date on sharp1801-v
  • tforsythe19 Dec 01, 2008
    How do you set the date and time for a EL1801V calculator?
  • Anonymous Mar 13, 2014
    i have a sharp 53210 calculator and the number are not showing full, e.g 5 will looks like a 2 ect please help
Anonymous
SHARP EL-1801V DON'T KNOW HOW TO SET THE DATE AND TIME
Posted on Jun 12, 2008
Anonymous
  • 682 Answers
If your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
Posted on Mar 09, 2008
Trying to replace the paper roll on a sharp EL1801V
1 Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    After changing the ink roller, the machine is printing nonsensical characters.
    You have a IR 40T replacement cartridge instead of a 40T
    These are sold under the NR42-2 number as replacements for the Sharp 1801P but they do not fit. IF you look closely at the Sharp Models it lists on the package, it will say Sharp EL-1801V. I have not found a working replacement yet.
    Dec 02, 2009 | Sharp EL-1801P Calculator
    EL 1801V - how to set time/date?
    To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
    Sep 02, 2008 | Sharp EL-1801P Calculator
    Sharp EL-1801V Calculator
    Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
    Apr 02, 2008 | Sharp EL-2630P Calculator
    Time/Date
    To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
    To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
    Feb 20, 2008 | Sharp EL-2630P Calculator
    Sharp EL-2630P Calculator Logo
    1,777 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    amir hamza
    amir hamza
    Tareq Bin Mostaq...
    Tareq Bin Mostaq...
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
