20 Most Recent Sharp AR-C260M All-In-One Printer Questions & Answers
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
Sharp AR-C260M... | Answered on Jul 23, 2013
Error ce-02 means that the computer the image is being sent to is not running sharps "network scanning tool" which is part of the sharpdesk software suite
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_0c6af8f6331df718
Sharp AR-C260M... | Answered on Sep 26, 2011
That is a heat error and easy to clear.
On your machine press P * C *. That is the #*C*.
The machine will enter diagnostics. In the small box enter the number 14 and press start, It will then give you an option to press the number 1 to clear the fault.
Once there, enter 1, then press start. Press clear a couple of times and the machine will reset and run.
You could have a fuser problem. But I would say 95 percent of the time doing the P*C* will resolve it.
Sharp AR-C260M... | Answered on Aug 09, 2011
It seems your color cartridge have issue try changing the color cartridge or clean the head cartridge head and try.
Regards,
JJ
Sharp AR-C260M... | Answered on May 13, 2011
May i help, Test your power source if present.,Check fuse if functional, check power button if damage or broken, Commonly on that unit is the power button may dislocated, so try to see it well.
Sharp AR-C260M... | Answered on Mar 09, 2011
Windows 7 is not supported for this printer.
Sharp AR-C260M... | Answered on Mar 06, 2011
You don't, unless you can find a way to replace the countdown CRUM chip. Besides, those cartridges wear out and put uneven toner on the foam roller. Best to buy a new one.
Sharp AR-C260M... | Answered on Mar 01, 2011
Your AR-P16 or P16N print controller is broken or needs a firmware flash.
Sharp AR-C260M... | Answered on Feb 10, 2011
The IP address or computer name your copier has been told to scan to ain't there no more. get rid of all your scan profiles in the NST and web page and resubmit.
Sharp AR-C260M... | Answered on Feb 09, 2011
Go to Sim 26-38 and set to zero. when your machine reboots and still locks up you will have to reset some of your counters (drum, transfer, etc)
Sharp AR-C260M All-In-One Printer Logo
Popular Tags
61 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
network error ce 02
  • Office Equipment & Supplies
