It seems to be running ok, just not picking up
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
SOURCE: vacuum cleaner not picking up
My M.R. cleaner had the same problem. I found the drive belt for the beater bar was broke.
Turn the cleaner over when running and if the beater isn't turning, then the belts gone.
New belts on E-Bay £4-$7 for 2.
SOURCE: I have a Eureka Altima vacuum cleaner that doesn't
That means that you need to replace the belt. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
SOURCE: My Hoover vacuum cleaner is not picking up from
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
