20 Most Recent Hoover F7429-900 Upright Steam Cleaner Questions & Answers
OK usually the brush will not turn as it gets locked up by the fibers in the stuff sucked up, usually one has to disassemble the head, or some other way, free up all the stuff tangling the brush, on the shaft, and stopping it from turning. I usually use a sharp knife or scissors, etc, to cut and hack carefully away this stuff that clogs it up, I usually have the vacuum on when I do this and the stuff removed simply get sucked up as i do it. it doesn't take much to stop them, just look carefully inside the head and you should see what i mean.
Hope this helps?
Hoover F7429-900... | Answered on Jul 15, 2011
Copied this from the owners manual off of Hover internet site. Brushrolls are not spinning 1. Belt needs to be changed. 1. Refer to how to change belt. 2. Something is jammed in the brushroll. 2. Remove jammed item from cleaner with unit turned off and unplugged. There is a diagram on page 26 of the owners manual if you have it. I have the same kind of machine. One thing i have found with this type of unit it likes to be clean. So you may have to just take it apart and clean it out. You also could take it to a repair shop to have done if you are not sure how to do it.
Hoover Vacuums | Answered on Mar 18, 2018
Most anything can be fixed if the needed parts are available. You will first need to examine closely to determine where the water is coming from to determine what the problem may be. It is most likely a valve, hose, seal, fitting, tank, etc.
Hoover Vacuums | Answered on Mar 17, 2018
It seems it must be blowing out from somewhere. Try to figure out where by feeling for air blowing to try to determine where it's coming from and why.
turn the light assembly on the front one half turn to the right to release the belt then remove the brush holder it tilts out then remove the hidden screws on the front and the bottom of the case
Hoover Vacuums | Answered on Mar 15, 2018
Hoover SteamVac brushes not spinning
This video might help ... it is a related model.
The usual problem with these brushes is that they stop spinning ... not that they will not stay in.
As shown in the video ... they just clip back in by pressing the whole unit in to the housing. The protruding square pin in the middle does need to line up with the housing drive ... or it will not press in. The two alignment posts need to be in the correct position also. The brushes need to be hand wriggled to help alignment so the square peg will enter the square drive hole.
If you are successfully getting the brush unit all the way in ... and it does turn when the unit is turned on ... all I can think of is that the alignment posts have somehow broken...
I recommend blowing it out with a air compressor, some can be washed with water but water can make the fine dust pack into the pores. If it is over a year old it should be replaced as should the other filter or filters depending on your specific model.
Hoover Vacuums | Answered on Mar 14, 2018
Probably a poor design factor that really cant manage the dog hair in the first place !! I always suck a few small coins up and you can hear if they get a unrestricted journey to the dust bag , if you have a blockage you will not hear them clank around as they will get jammed !! this will let you know that your machine is blocked or jammed up causing poor suction !
Hoover Vacuums | Answered on Mar 13, 2018
Bank's Vacuum has the manual for the Hoover Spot Scrubber (Model FH10025, aka Hoover MultiSurface Deluxe Portable Cleaner):
They also currently show it in stock, whereas most places no longer carry this model.
Hoover Vacuums | Answered on Mar 09, 2018
Hoover F7429-900 Upright Steam Cleaner Logo
3 questions posted
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
model f7429 900 will not
  • Vacuums
