20 Most Recent Hoover U9145-900 Z Bagless Upright Vacuum Questions & Answers
check connection and brush if stuck.
Hoover U9145-900... | Answered on Apr 09, 2013
You will need to take the top off. It is easy: turn the vacuum over and look at the bottom (where you can see the beater bar). There are some deep screw "wells"; these are the screws you need to take out plus the 4 silver looking screws that hold the beater bar plate in place. When you bet those out, there there will be a "notch" at the front, behind the LED light you will have to disengage. Turn the vacuum back over and take the gray top off. You should be able to see the engagement latch that is attached to the handle. This is what opens and allows the flap to shut. It has a spring attached that may have come loose. Good luck.
Hoover U9145-900... | Answered on Apr 25, 2009
On page 11 of your manual it talsk about the pre-filter which I think is the one you are talking about, it isn't to come out, so either is pressed in or glued. But if this is less then 1 year old it is under warranty. If it is then take it in and have it repaired,
http://www.hoover.com/pdfs/manuals/U9145900.pdf
Hoover U9145-900... | Answered on Jan 30, 2008
check for tank not seated properly. look for air leak at all seals. no water unless clean water tank is correctly seated.
Hoover Vacuums | Answered on Nov 11, 2018
If the brushes don't turn it is usually the turbine bearing have seized. Take it to your local vac shop for repair. The turbine can be rebuilt or replaced.
Hoover Vacuums | Answered on Oct 30, 2018
Make sure the dirty water tank lid is seated properly. If that doesn't work, take it to your local vac shop
What model is your steamvac ?
Are you sure about the model number? I don't see any Hoover FH20240 models. The Hoover Max Extract 77, FH50240, manual is available from Hoover. See https://www.hoover.com/max-extract-77-multi-surface-pro-carpet-and-hard-floor-cleaner/FH50240.html . The direct link to the manual is http://tti.a.bigcontent.io/v1/static/FH50240_Hoover_User_Manual .
Most Hoover manuals are available here: https://www.hoover.com/manual-video-search/ or https://www.hoover.com/user-manuals/ .
I hope this helps.
Hoover Vacuums | Answered on Oct 29, 2018
Make sure the dirty water tank is sealing in place . the seal drys out when not being used and might need vaseline on it
Hoover Vacuums | Answered on Oct 26, 2018
Its normal other company / brand they are good in customer service, hoover is good in selling bad in customer service its hard to find a perfect company /brand that's good in selling and customer good providing service after sale.
Hoover Vacuums | Answered on Oct 25, 2018
Hoover U9145-900 Z Bagless Upright Vacuum Logo
Popular Tags
7 questions posted
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
brush not turne
  • Vacuums
