If the voltage for the tv is mains voltage then you will need an inverter to bring the power up the mains voltage for the tv
if it is 12 volts unit then check that the battery is set at 12 volts or the switch on the tv is set for 12 volts.
Testimonial: "Thanks Bill, have checked and in fact was an issue with the TV lead accessing Solar battery. Checking all details suggested helped work out issue in the end. Thanks for your help. Cheers."
SOURCE: remote code for the dvd/tv combo
Our remote broke and I can't find one that will work for the DVD.
SOURCE: universal tv remote control codes for a hikona tv/dvd combo
you have to set the code for TV alone, then code for DVD
SOURCE: lost remote for akai tv/vcr/dvd set
my, need code for programation my combo in remote control rca
SOURCE: No code for the Emerson tv, dvd combo, model #LD200EM8
i have a remote and i can't find or program it to my tv combo tv/dvd
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
