I changed image unit yellow in Bizhub C450, it works really beautiful, but i got printing problem: everything i try to print from network does not printing. The documents left every PC, the green data LED of C450 is flashing but nothing happens, just flashing till i switch OFF. I checked the problem at PC drivers, router, even the IP adress from C450. It seems everything is set well, unchanged, same as before (when worked fine). Did anyone meet same issue? Need help please, thanks!
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Testimonial: "Hi, i tried even changing the whole network, including the router. Now i have a complete new router (the other was an older one, and didn´t know if that is the source of problem or not), and now i have a complete new network, new IP range also. C450 also has new IP! The whole network works fine, but the C450 has the same issue: every PC is seeing it, if i send to print a test page, it goes in less than a second, and almost in same time the C450 wakes up, and data LED starts to flash... and is flashing many many minutes, if i let it, even hours (i was sending a test page yesterday, and today was checking, nothing was printed, just flashing that data led)... :( Really don´t know where the problem can be, if i try to use the C450 as stand alone, makes copies well, and also scanning, makes the duty in great quality... I wanted to try to connect via USB to one of the PCs, but as i see does not have any USB :( Please anyone if has any idea, or had same issue... Everything is appreciated !"
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
SOURCE: Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
SOURCE: Konica Minolta bizhub C250 won't print or scan.
Your first priority should be to put it on the network , for this u should give the printer the IP 192.168.2.XX where XX varies from 4-99 . Please make sure that no other device should have the same IP which u are assigning it to the printer and and try to ping on the network.
SOURCE: I have a konica minolta c450 copier and I was
Hi, IC-402 external fiery does brightens color print, It all depends on what texture of printing you are looking for...
Normally if i were you i would go for something like
IC-402 external fiery, it's has a Good quality color printing..
No need to bit around the bush for too long,Go get it and try it out,but make sure you read instruction carefully before using it..
Take care.
Update: After changed the IU with another one brand new, and the issue still not changed, i'm absolutely sure, that the source of this problem IS NOT THE I.U. ! Also the machine is working excellent as stand alone (copy and scan), only the printing form PC makes jokes.
Anybody? Please, help is needed. Network printing still not working... :(
