Question about Konica Minolta bizhub C450P Laser Printer
Hi, on Konica-Minolta Bizhub C450 printing speed is very slow. Attached to Ethernet, Data via TCP/IP. Speed 100 MBit fullduplex. Sending a full color A4 page with 300 dpi; f. E. from Photoshop. The C450 shows the blinking green Data LED for about 10 minutes. Then the printout begins. 10 minutes; impossible I think. The Computer OS is Win XP or 2000, the driver PS or PCL 2.50 or PLC V3.01. All the same behaviour. Can you give me a hint? Any known dependences? Amount of Memory of the C450, Firmware, Settings?
Posted by gb2335 on
  • gb2335 May 12, 2011
    Thanks fadsshi, but there is nothing regarding my problem - search for C450 nothing will be found.
    And you wrote you have been faced with this Problem; why can't you tell me, what causes this slow speed?
Adekoya Sunday
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Am having little Challenge if I send job to printer Bizhub c451. D job will enter printer and it will wrote System Printing and it will not print
Posted on Oct 23, 2018
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Could be the file size, could firmware have a tech come out update it. C450 is legacy machine. HDD installed and memory amount? try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 18, 2017
5 Related Answers
Anonymous
SOURCE: bizhub C450 error (C-0212)
I've just had the same problem - empty the LCT and close it. Open and close the front door of the machine. This should clear the code (it worked for me). Then reload the paper in the LCT as previous
Posted on Mar 14, 2008
Anonymous
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
Anonymous
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
Anonymous
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
taminol
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
How can I download driver for Konica Minolta bizhub C-252 on windows XP and direct to unit with ethernet cable?
Robert, C-252 Copier prefers that you give it a IP address (Call Static IP) Do not use DHCP which the network determines .
Go Administrator, Admin One Network TCP/IP have your network administrator determine best IP address for your network.to give the copier
Dec 17, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Why IR105 slow printing of PDF copies
theres a check box in adobie that says print as image check that and it should speed up your printing tenfold other wise its sending each line increasing the size dramatically
Jun 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta c450 Network Print- Data comes at the machine end but no print
does this happen with word , pdf, web pages, email? what other indication display on screen
Jan 02, 2014 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Copy speed slow ( on bizhub c450 ) and show three angle shape
good luck
Description:
The machine copies very slow and well below the rated output for black and white and color.
Solution:
CAUSE: The machine memory is corrupt.
SOLUTION: Perform a data clear:
1. Browse to the NIC/Log on as Administrator/Select the Scan tab/Import Export and back up the one-touch addresses to the desktop.
2. Enter Tech Rep mode.
3. Select System 1.
4. Select Data Clear and press start. Wait for the machine to cycle OFF/ON and for the POWER OFF MACHINE WITH THE MAIN POWER SWITCH message.
5. Import the one-touch list back to the NIC.
6. Re-install the HDD and power the machine OFF/ON.
7. Reset the Marketing area to U.S. and the target to U.S.
8. Re-install the TCP/IP address and power the machine OFF/ON.
Sep 14, 2009 | Office Equipment & Supplies
Printer Busy message
check your mac connection settings, change if needed, try install new printer.
Dec 07, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C450P Laser Printer Logo
378 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
