I can feel the paper in the back when I try to push in the paper tray
Remove any loose paper in the loading tray.
Press the Resume button on the from of the printer.
If the paper jam is cleared, move to Ensure the printer carriage can move freely.
If not, continue to the next step.
Remove lodged paper one sheet at a time, starting in the middle.
Check for any remaining bits of paper.
If not, continue to the next section.
The best custom research paper writing service to learners across the globe
SOURCE: We have a sp 3250 all in one printer. We had a
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
SOURCE: My kodak All-in-one printer ESP9 goes instantly in
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
SOURCE: error code 3528 keeps coming
Check the complete paper path very carefully, it only takes a small fragment of paper stuck somewhere to signal a paper jam. Also check that the paper sensors have returned to their normal positions. See that the printer has not picked up a second sheet of paper and this is somewhere in the path.
SOURCE: I have a paper jam inside my new ESP 7250 printer.
maybe just a very small piece of paper, look carefully on the paper path
Testimonial: "Thanks!!!!"
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
