20 Most Recent
Kodak ESP C310 AllInOne InkJet Printer Questions & Answers
Printer has lines that print very light
The obvious, you have full /new ink? If so, you printhead is starting to go bad. 2 ways to correct, Either use live chat with Kodak (kodak.com/support), after a few questions, they usually replace the printhead for free. Or call Kodak or order the printhead on line..it is about $10. Hope that helped.
How to replace a fuse in a kodak eps c310 printer
What I usually do is if I can't figure it out, I do a search for a diagram on the internet. I use Google. If worse comes to worst, I find the Customer Care phone number or try to find a chat connection to speak to a tech about the problem. I would have the printer plugged in with fuse in hand.
Bidirectional support is disabled
Sometimes the answer is to remove it from your devices and then add it again. You can also completely delete driver. I have done it, but forgot. You can research that on internet. You sometimes have to start all over again.
Bidirectional support disabled
See this... http://support.en.kodak.com/app/answers/detail/a_id/1294/~/error%3A-bidirectional-support-is-disabled/selected/true
Paper jaming
Here is what I did to fix the aggravation and annoyance this particular printer caused me. I let my son take it to the back yard and smash it with a bat. Then he took it to the dump.
I hope this helps.
My kodak printer esp 3.2 is giving me an error
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
