No option for cd/format only usb
SOURCE: How do I format a disc (DVD or CD) on Windows XP?
You only format a CD/RW or a DVD/RW, which are re-writeable.
Regular discs do not need to be formatted (CD-R or DVD+R, DVD-R, DVD+R DL, etc.).
To format the DVD/RW idisc, use the "burner" software ( Sonic?, Nero?) and choose [Tools] [Erase Disc] (erase is the same as format)
Testimonial: "Thank you I will follow your instructions"
SOURCE: formatting CD or DVD
go www.windowsreinstall.com and then see the guide u will the screenshots and u can format and then reinstall it will give the fix
SOURCE: i have a hp pavilion
You can dump the windows98 setup to your usb flash drive using wintoflash software and boot your system using usb flash drive. Proceed with the installation steps for win98.
Regards,
Sreejith
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
hope this helps
