Getting down on the floor is a real struggle
SOURCE: The door seal is torn.
Pay the repair guy, even if it didn't include the part (seal) its cheap at $200. I replaced my door seal, I think the part cost me $36. In order to do the job correctly you need to remove the top, take off the front, remove the counter weight (to get room to work and not bust your knuckles). If you have an older machine the replacement seal is not a direct match. My seal won't allow the door to close completely and i have to lean on it to allow it to lock on start. I have had the seal in for about 4 months and am noticing the door closes better and I only have to lean on it a couple of times.
I replaced my seal because of the mildew problem caused by poor drain hole design. How does your seal get torn?
SOURCE: how to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
SOURCE: torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
SOURCE: torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
SOURCE: the door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
shaun
