Freezers Logo
Question about Whirlpool Freezers
Whirlpool upright freezer is working fine but an alarm is sounding intermittently. It sounds different than the high temperature alarm. Can't find codes. What does it mean?
kishnakant chaturvedi
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 307 Answers
If your Whirlpool upright freezer is working fine but an intermittent alarm is sounding that is different from the high temperature alarm, it could indicate an issue with the door or the door switch. The alarm is designed to alert you if the door has been left open for an extended period or if the door switch is malfunctioning. Check the door seal to ensure it is tight and the door is closing properly. You can also try cleaning the door switch to see if that resolves the issue. If the problem persists, it may be necessary to contact a professional for further assistance.
Posted on Feb 14, 2023
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
1helpful
Kenmore upright freezer not freezing
Kenmore & Whirlpool refrigerator frost build up in freezer not ...
? 7:02
www.youtube.com/watch?v=gVXT7pZyk_o
Sep 12, 2013 - Uploaded by ApplianceVideo.com Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
Freezer Troubleshooting - What to Check Before You Call a ...
www.realestate.com > Realestate.com Blog > Articles
Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
Making alarming buzzing sound. Still freezing fine
putting unfrozen food in a freezer can raise the temp to cause it to go off allow 24 hours for it to stop if it dont replace the buzzer
2answers
Alarm is going off how do I stop it
The best temperature is the midpoint. Typically 3 or 4. The alarm will go off once the temperature goes down to the freezing point.
1helpful
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
2helpful
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
4helpful
2answers
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Top Whirlpool Freezers Experts
David Shaub
mark warfield
mark warfield
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
