20 Most Recent Whirlpool ED5HHEXT Side by Side Refrigerator Questions & Answers
should say on box of new filter
Whirlpool... | Answered on Apr 10, 2018
You have to do these checks. Check for build up on the condenser coil behind the fridge. Check for MASS build up of frost in the freezer section. If you have that, unplug the unit for 3 days and let it defrost. You will have to check the parts on your evaporator to see if they're operating properly. Also make sure the compressor is even running. Try turning the fridge on. If you're not getting a hum out of the compressor but can hear it clicking, you more than likely have bad start components on the compressor. Also if the compressor isn't running, try tapping on the temp display/thermostat where you adjust the temperature if it starts, you probably have a bad thermostat. The fridge sounds like its been running for 2 days and it's dead hot in the unit, you have a system problem and should consider buying a new one.
Whirlpool... | Answered on May 19, 2014
Generally, ice cubes sometimes get stuck on the flexable cover and will not close properly if they get stuck between the flap and the chute. A hair dryer blasting on the flap will dislodge them and let the mechanism close properly
Whirlpool... | Answered on Jan 10, 2011
There is a wire lever that allows for the icemaker to be turned off. If it is in the up position the icemaker will not make ice.
Whirlpool... | Answered on Jan 02, 2011
there is a magnetic vinyl covered seal glued all around the door frame to seal the refridgerator from escaping cold. If this seal has come loose, it will adhear to the door frame a little after opening and then be pulled back and make a slapping sound. Check this seal to be sure it is not torn loose.
Whirlpool... | Answered on Dec 28, 2010
Most refrigerator Manufactures have tested these machines in hot and cold weather and weather will effect operation and electricity consuption.
As far as cold weather goes It would run much better in cold weather than hot. As far as it being in the garage : It will wear on it faster. The humidity is not good on them and they get more dirt through the system and will need its normal mantenance more often. not to mention bugs and rodents like to find a warm place to hid with fee dinking water and a refrigerator provides that for them.
Whirlpool... | Answered on Jan 09, 2010
Hi Lucille,
NO This model does not have a water filter.You will need to complete disconnect the ice maker and clean it out. Then remove and flush the fill tube. If ice still appear dirty, you may to replace the water valve,the water tube and the ice maker too. I will link the parts needed and see the repair video on how to access them. https://www.appliancepartspros.com/whirlpool-whirlpool-icemaker-kit-4317943-ap2984633.html
https://www.appliancepartspros.com/whirlpool-tube-water-w10823511-ap5989588.html
/whirlpool-water-valve-4318046-ap3103466.html
Whirlpool... | Answered on Jun 19, 2019
Hi Kathy,
Simply put YES
https://www.sears.com/search=w10295370
This is the link to the replacement filter
Hope this help
JP
Whirlpool... | Answered on Jun 18, 2019
Whirlpool ED5HHEXT Side by Side Refrigerator Logo
Popular Tags
13 questions posted
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
regularly maintanance
  • Refrigerators
