Samsung wireless LAN Adaptor
SOURCE: What brand USB Wireless Adaptor will work with my LG TV
Any brand of USB Wireless Adapter will work. Netgear, Linksys, etc
SOURCE: I purchased a Sony Bravia
I believe you have entered Access PIN for the network but check at the same time if you have entered user name password for your internet service provider.
Reply if you are able to resolve the issue
SOURCE: I have a samsung LCD
Hello jrlj2002 ,
Here i try to help you.
First when you connect that LAN adapter (dongle), pop up messege will appear on screen. Choose wireless conection. My suggestion use manual setting.
Enter to user menu --> setup --> change Network type to wireless, search signal for SSID than insert security key.
after it, TV will search SSID. If it work , screen will appaer pop up conected.
Some cases , conection filed if wireless transmiter and TV too far or not perpendicular. Try it near wireless transmiter.
If it stil not working, change type of your wireless transmiter to free (no security code) for testing conection.
I hope that will help you.
Thanks.
SOURCE: I have a wireless Westell
It is plug and play of a sort but you need to set the connection type and your network access password as detailed in the manual at the following link. (Page 32 to 35)
http://www.samsung.com/us/support/downloads/LN46B630N1F
Bluetooth is not WiFi, they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
