Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center - White Logo
K
Keith Knapp Posted on Aug 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Frigidaire stackable laundry center will not fill with water?
I have the unit plugged in, the water is turned on, and the unit will not put a drop of water in the drum. When I push start it beeps like 3 times at me. What do I need to replace?
  • Official Brand Answer 2,267 Answers
  • Posted on Aug 26, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290110
Points
2557
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Jan 24, 2008
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Anonymous
  • 4 Answers
  • Posted on Mar 20, 2009
SOURCE: 3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Anonymous
  • 6784 Answers
  • Posted on Jul 20, 2009
SOURCE: my frigidaire stackable dryer wont turn on when i
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Anonymous
  • 154 Answers
  • Posted on Oct 22, 2009
SOURCE: Humming, but no spinning
It could be the capacitor which kick starts the motor.
they are relatively cheap to replace.
Ash
Anonymous
  • 278 Answers
  • Posted on Dec 09, 2009
SOURCE: My dryer (frigidaire stackable washer/dryer) just
Howdy: The circuit breaker could have popped in the motor. Maybe the selector on/off switch has gone south. Will need a AC meter to check voltages from switch to motor. Doug
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Frigidaire gallery series washer dryer stackable unit will not fill all the way
Hi Friend, this is Z. Thank you for your inquiry!
I understand that your Frigidaire laundry center will not completely fill. Here are a few troubleshooting tips that may help you get to the root cause:
First, disconnect power from your washer. It is good to wait roughly ten minutes and then turn on your laundry center? Did the issue persist? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, your laundry center may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
1helpful
Stackable dryer
Hello - Generally speaking, Frigidaire laundry centers do not have fuses. The unit has a thermal limiter usually located in the dryer.
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
1helpful
Frigidaire Laundry Center (FGX831CS1) overflowing.
There are a few issues that could cause the overfilling...failed water inlet valve, failed water level pressure switch, hole in pressure system air hose or air hose disconnection to name a few. Need to have professional evaluate, or it could happen again. Call home insurance if there are water damages to file a claim, and they can handle it from there usually.
2answers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
6helpful
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
