20 Most Recent Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center - White Questions & Answers
How do I replace the dryer belt?
Hello Philip, I appreciate your inquiry!
Based off the information you have provided you need help with replacing the belt on your Frigidaire laundry center. In order to access the pulley you would need to disassemble the laundry center. I would recommend seeking assistance from a professional technician for proper disassembly of your laundry center. Incorrect disassembly could cause personal harm or future issues within the laundry center. Best of luck! -Matt
12/17/2015 5:28:29 PM • Frigidaire... • Answered on Dec 17, 2015
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry! I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
8/26/2014 5:42:35 PM • Frigidaire... • Answered on Aug 26, 2014
How do you change the heating element
Good Afternoon Friend, I understand you want to know how to change the heating element in your laundry center, model# FFLE2022MW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician, for further assistance. They have been trained on you appliance and should be able to change the heating element with ease. Hope this is helpful. -Best Regards- WP
7/3/2014 8:02:56 PM • Frigidaire... • Answered on Jul 03, 2014
Dryer heat not working
Without knowing your problem, I would guess that the heating element has burned out. This is a common issue with many dryers, regardless of brand. The hearing element in a clothes dryer is like any other heating element, such as in a space heater, heat gun, or hair dryer. It is basically a continuous coil that is held in place by insulators, usually ceramic. As the element ages, the coil becomes brittle and can often break. When a breakage occurs, the circuit is no longer complete and will not produce heat.Replacing one is fairly simple.
  1. The first thing that you should do is unplug your dryer.
  2. Once unplugged, remove the exhaust duct.
  3. Use a screwdriver to remove the electric access panel in at the rear of the dryer.
  4. Locate and remove the heating element.
  5. Inspect the element for a break in the coil. The problem is not always obvious so it may be good to do a continuity test on it.
  6. Replace part if necessary. Elements will usually run $20 or so.
  7. Assemble in reverse order and test.
This website has some really great detailed step by step instructions on replacing a heater element. Good luck.
2/19/2013 11:40:10 PM • Frigidaire... • Answered on Feb 19, 2013
2answers
Re: Frigidaire Dryer FEQ332CES0, Heating Element Connection
If the terminal is 5/16 it needs to be 5/16. The reason is that it passes the correct resistance. The smaller the contact, the more resistance and heat. You may be okay with a 5/16 connector in 250'F and that is probably the best option. However, I would image that any local wholesale electrical wholesaler would carry them. https://www.google.com/search?q=5%2F16+high+temperature+spade+terminal Nedco and CES are my go-to wholesalers https://www.google.com/search?q=electrical+wholesaler+near+me ..
3/5/2024 12:44:54 AM • Frigidaire... • Answered on Mar 05, 2024
Frigidaire Affinity Door Open
Help in the link which also refers to the thermal limiter. It is a gas appliance and should be only serviced by a certified and registered gas technician. https://www.google.com/search?q=Frigidaire+Affinity+Door+Open ..
2/23/2024 8:17:23 PM • Frigidaire... • Answered on Feb 23, 2024
Frigidaire LP/ Propane dryer model GLGQ2152ES3. It dried clothes one day the next day it didn't heat up. Changed the ignitor and still no glow. What is the next step. Thank you
It is a gas appliance so has to be worked on by a gas certified technician. Call for service. That is the law. ..
2/16/2024 4:19:34 AM • Frigidaire... • Answered on Feb 16, 2024
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
  1. Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
  2. Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help. I hope this is useful.
1/9/2024 1:13:45 PM • Frigidaire... • Answered on Jan 09, 2024
2answers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post! If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website. Best regards.
10/11/2023 1:26:50 AM • Frigidaire... • Answered on Oct 11, 2023
2answers
Frigidaire dryer model gler642as3 making a grinding thumping
Thumping and grinding is indication of a worn rear bearing and worn drum slides at the front. They are made of felt and are supposed to be oiled periodically. They are an easy replacement on older machines. https://www.google.com/search?q=Frigidaire+dryer+gler642as3+parts ..
8/28/2023 6:36:04 PM • Frigidaire... • Answered on Aug 28, 2023
Looking for a picture of the wire colors where they go on a Frigidaire electric dryer timer part #131225100
The important part that is missing from this question is the model of the dryer as this part may used on multiple models. The correct Google search query is frigidaire (model) replace timer or frigidaire (model) timer wiring diagram The result will be like this and you can click on the images tab as well. https://www.google.com/search?q=%E2%80%8Bfrigidaire+(model)+timer+wiring+diagram I deleted the Answer that you got previously as it was from an AI Answer Bot https://www.fixya.com/users/rege-oluwaseun I am an advanced human being to provide comprehensive and accurate information based on authoritative non-specific answers ..
8/23/2023 4:33:11 PM • Frigidaire... • Answered on Aug 23, 2023
Frigidaire Electrolux GLER331AS2Is Dryer. Is it possible to replace JUST the heating element and not the whole Dryer Heating Element Assembly?
Question edited for clarity. Question moved from Cars and Trucks. No, not normally, it comes as a unit and this is standard procedure. If it is failing in three years, you have an airflow issue which is causing overheating. https://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=20&SearchTerm=GLER331AS2&ModelNum=GLER331AS2&ModelID=1107102 Having said that, here are bare coils if you want to try it and the price is a lot more favorable, just make sure voltage and wattage matches.
5300622032 Frigidaire Dryer Heating Element Coil
Reliable Parts https://www.reliableparts.ca > ... > Frigidaire Dryer Parts This is a genuine OEM part that works for some models of Frigidaire, Electrolux, White Westinghouse, and Tappan models. The 5300622032 Frigidaire Dryer Heating ... $56.81 · ‎In stock
Amazon.ca https://www.amazon.ca > frigidaire-dryer-heating-ele... Wadoy Dryer Heating Element Heater coil 5300622034 Compatible with Frigidaire Gibson Kelvinator Ken-more Tappan Westinghouse · 4.24.2 out of 5 stars (37). ..
8/8/2023 2:55:48 PM • Frigidaire... • Answered on Aug 08, 2023
Can a Frigidaire GLER331AS2 be wall mounted upside down?
it is you's to mount upside down, whether or not it works well.
7/22/2023 9:02:10 PM • Frigidaire... • Answered on Jul 22, 2023
I have a Frigidaire Affinity dryer. It is heating but is taking 3 Cycles to dry a small load. .
SOUNDS LIKE FAULTY THERMOSTAT / REGULATOR FOR HEATER ELEMENT, COMMON PROBLEM IN DRYERS
6/24/2023 5:50:57 PM • Frigidaire... • Answered on Jun 24, 2023
Frigidaire dryer model LEQ332DSO Stops after a few minutes
There are several things it could be, but before you start throwing parts at it give these folks a call at their 800# tech line. https://www.repairclinic.com/ProductDetail/641599?symptoms=1
6/18/2023 2:59:42 PM • Frigidaire... • Answered on Jun 18, 2023
Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center - White Logo
8 questions posted
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
change dryer belt
  • Dryers
