20 Most Recent Frigidaire Affinity AEQ6000WH Dryer Questions & Answers
Can o still use the dryer with the E68 code
Or is there a risk of fire ?
Frigidaire... | Answered on May 30, 2019
Over heating.Check for block dryer vent.
Frigidaire... | Answered on Mar 06, 2014
There is a fuse inside (not sure where on that model) that kills the power. There is also thermal fuses and thermostats that will prevent the heating element from getting power (usually clogged vent). But no power is the fuse (usually encased in white plastic so it doesn't look like a fuse.
Frigidaire... | Answered on Mar 01, 2014
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Frigidaire... | Answered on Aug 17, 2013
Hello Timothy Johnson - Generally qualified technicians often perform complicated part replacement such as this. If I was in your position, I personally recommend contacting a professional to accurately diagnosis the precise issue before investing in parts that may or may not be the root cause. You can often locate a certified service provider through the manufacturer website.
Frigidaire... | Answered on Mar 11, 2013
Hello christinwogo - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Frigidaire... | Answered on Mar 03, 2013
Hello difow - From what you are describing the issue could be related to a damaged hinge or front panel. Consult a professional for an accurate diagnosis and to assist with the repairs.
Frigidaire... | Answered on Feb 19, 2013
Frigidaire Affinity AEQ6000WH Dryer Logo
76 questions posted
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
dryer running super hot barely touch
  • Dryers
