It depends on which Ricoh model.
Some Ricoh copier/printer use a corona wire for charging the drum, so SC302 means that the corona wire is ether broken or have some current leak. but in most case the wire is broken.
Other Ricoh copier/printer use a charge roller for drum charge, so on this model SC302 usually appear when the charge roller have a bad contact.
THE CHARGE ROLLER IS LEAKING BECAUSE THE DRUM ONE SIDE COATING IS DAMAGED. THE CHARGE VOLTAGE IS DIRECTLY GOING TO ALUMINIUM SURFACE. SO COVER THAT PART OF CHARGE ROLLER WITH A CELLO TAPE THE ERROR WILL NOT COME.
