20 Most Recent
Ricoh Aficio MP 2000 Black and White Copier Questions & Answers
Richo Aficio MP 2000 paper
Shut it off and unplug it from the wall, for a couple of min, then try again, if still na jam, you better look again.
SC 500 error code on a Ricoh MP161
main motor can turn that is why getting code. can be from photo conductor, to fuser or gear broke in back of copier. Will need tech for this one.
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Error code sc500
Main motor lock up could be the photoconductor unit or main motor or gear that runs off of it
Paper jam on exit sensor MP2000
change the exit sensor or contact one of technicians on
- Auckland
Level 2, 60 Stanley Street, Parnell
P.O. Box 68-024, Newton
Auckland 1010
Phone 09 - 374 0701
Fax 09 - 368 6001
Email [email protected]
- Wellington
123 Taranaki Street
P.O. Box 10-258
Wellington 6011
Phone 04 - 381 7600
Fax 04 - 381 7615
- Hamilton
Cnr Anglesea & London Streets
P.O. Box 758, Waikato Mail Centre
Hamilton 3204
Phone 07 - 957 4500
Fax 07 - 957 4519
- [email protected]
My copier ricoh aficio mp 2000 makes a continuous
MP2000s often have creaking and squeaking issues. Typically it's the brass bushings that ride on roller shafts, so if you can isolate it to an area and clean and lube the bushings, you might be able to fix the noise.
Sc484
Waste toner bottle full. The toner full sensor goes HIGH
for more than 500 ms, indicating that the waste toner bottle is full.
