Washing Machines Logo
Posted on Jun 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine taking about 3 to 3 and a half hours to do full wash and dry cycle also not taking in all softner
Anonymous
Level 2:
  • Expert 82 Answers
  • Posted on Jun 28, 2009
Anonymous
Expert
Level 2:
Answers
82
Questions
0
Helped
32431
Points
186
The cold valve has gone on the most washing machines there are 2 or 3 valves
e.g 1 hot 1 cold
or 1 hot 2 cold
the cold vale does the conditioner and it also puts cold water into the machine when it dryes into the condenser unit this cools down the steam off the clothes back into water
My dishwasher stays on the washing mode, it never moves onto the dry cycle.
Seriously, you may want to call a service repair guy to look at this unit if it is something you want to keep and is out of warranty. You are wasting lots of energy, with washing and draining again and again.
Feb 02, 2016 • Dishwashers
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Zanussi progress 1200
check the filter for blockages
1helpful
SMELLY washing machine
First i hope you have cleaned out your filter. For the smell: Switch from liquid to powder detergent, no fabric softner, not necessary. Clean the big gasket with detergent and run a half load (without clothes of course) very hot cycle with 2 cups of vinegar only. Leave the door open whenever possible. This helps in drying out your washer and preventing mildew. Shut your wall water valve after your wash
Click helped if really helped.
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Softner remaining in drawer after wash, then laundry is full of static after drying.
Try to do a cleaning wash without any washing. Add 5ltr of any brand of washing bleach and program a normal wash cycle. This will clean out the system and may solve your problem. It is a good idea to do this every few months as a routine.
3helpful
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
2answers
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Top Washing Machines Experts
john h
